Darkwood
TBH - its poorly design from start to finish, can only really see it working as a last man out switch option as it doesn't comply to any other system for student isolation/safety out there so must just be a master switch. The contactor TBH serves no purpose if this is the case because using a DP 20amp switch would have served exactly the same purpose so I suspect the coil is directly energised of the supply side but possibly through a key switch descretely located that the OP has missed otherwise I'll say it again 'What's the point in it?'
