Discuss Ring Main Tripping MCB in the Australia area at ElectriciansForums.net
I
irishsailor
A friend has just called saying his power circuit keeps tripping the MCB, he said all appaliances are plugged out?
Any suggestions lads
Irish
You need to ask some BASIC questions first, Has any one been playing with the wiring, is it the upstairs or downstairs ring, if downstairs is it wooden floors.
Number of outcomes downstairs with wooden floors could be water under the house seen this a few times, Rodent damage or even a loose wire.To be honest you would need to test it, Start with basic testing continuity then insulation test. Minimum insulation is 0.5 at 500v test.
Hey chaps.
I'm a little confused, an MCB provides overcurrent protection, where as an RCD provides earth fault protection.
The only time an MCB would operate is under overload conditions. (See below)
Do you mean RCD??
Cheers.
PS, sorry short circuit also, just become a Dad for second time no sleep and too much work....bad combo.
Also worth checking i know it sounds silly but he might be confused and think an rcbo is an mcb !
Regards
Kung.
Reply to Ring Main Tripping MCB in the Australia area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
Ring main was on a c40 rcbo so I tested the circuit everything was fine and dropped down onto a b32, It’s quite a long circuit but only serves...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
