stef - Jun 21, 2012 #1 Hi, I have a Robin Smart PAT 5000 tester, can't find the book, can't remember how to clear the memory. Anyone who can help, please? Thanks.
P patdev - Jun 21, 2012 #2 Hi Stef Dont have a Smart Pat 5000 manual but the 5500 manual says the following: From the main menu Stored test records can be deleted individually or all at once. To delete records press the clear button, the screen displays: Select record with UP/DOWN Press Go to and then Clear record. Hold GO down to clear all NOTE: Once deleted records cannot be retrieved. Last para is good advice so hope you have downloaded any test data you want to keep! Hopefully it is the same on the 5000.
F Former Sponsor TM Jul 3, 2012 #4 I can see that you got the problem sorted. If you still need it, PM me and I can e-mail you the instruction manual in a pdf.
Spike1947 - Nov 27, 2021 #5 Former Sponsor TM said: I can see that you got the problem sorted. If you still need it, PM me and I can e-mail you the instruction manual in a pdf. Click to expand... Hi Any chance to send me the .pdf [email protected] Cheers Spike
DPG - Esteemed Arms Patron Nov 27, 2021 #6 Spike1947 said: Hi Any chance to send me the .pdf [email protected] Cheers Spike Click to expand... Post is 9 years old and the member doesn't look to be active now.
Spike1947 - Nov 27, 2021 #7 DPG said: Post is 9 years old and the member doesn't look to be active now. Click to expand... Yes sorry, have just made a new post
