Discuss Roller Shutter Switch swap to 3 Gang Switch in the DIY Electrical Advice area at ElectriciansForums.net
Hello Everyone, (NOT DIY JOB, Need advise prior to calling an electrician on site)
Is it possible to swap a 3 phase rotary switch (roller shutter switch) to a 3 gang touch switch? left button for up, middle button for stop position and the right button for down.
Would like to utilise a Deta connect smart triple gang switch instead of the traditional roller shutter switch.
I am not an electrician and will be calling an electrician to do the job, I just want to know if this is possible before I call a professional to my home.
Thanks.
Without more information on the circuit that your rotary switch implements, it's difficult to say.
3 phase (do you mean 3 position?) and 3 gang - two entirely different things.
If you really mean this is a 3 phase supply/connection then no!
If the Deta switch you are thinking of is the type of thing I show in the links below, available in UK, then possibly OK.
But depends on limit switches on the shutters etc. Take advice from a competent electrician.
You need one of an appropriate current rating, but I think they are typically 10A, so depends on your shutter.
I have my doubts about the quality and robustness of these devices, but I have one on an electric window, and it has (so far!) done the job for a year or two.
If the rotary switch is the type it usually is (and only IF) it only has ELV inside of it, and the 3 phase supply is irrelevant. The switches have two NO contacts inside, with one closing when the switch is turned one way, the other closing when the switch is turned the other way, and neither closed when the switch is in the middle.
Reply to Roller Shutter Switch swap to 3 Gang Switch in the DIY Electrical Advice area at ElectriciansForums.net
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hey guys! New DIY 'new build' homeowner trying to not cause any damage to wiring! I'm looking to swap out the existing traditional light...
Hi Everyone, DIY advise required here please. I have the following wall switch, currently wired in as below and controlling external roller...
Sorry for the long first post, I wanted to be as thorough as possible. On my landing I have a 2-way switch setup, one of which is 3-gang, one of...
