Discuss Routing wiring near garage door springs in the UK Electrical Forum area at ElectriciansForums.net
I’m running an EV charging system in a garage it’s a 50 amp circuit 6 gauge wire can be Romax or in conduit Romax is cheaper but not an issue either way it’s easy access.
My concern is placement to make the run the shortest and easiest will be about six inches above the hardware and springs for door a garage door.
I have not been able to find any codes regarding this. I may be overthinking this but knowing these springs break and that they could possibly make contact with wires near them.
You will find that in the code book and it states that romex cannot be used if subject to physical damage
Reply to Routing wiring near garage door springs in the UK Electrical Forum area at ElectriciansForums.net
I used 1 inch emt conduit in the garage for 50 amp circuit for ev charger. I plan to use 4AWG wire. Please let me know which wire is est for...
Hi guys, I plan on installing a ring floodlight onto the brick centered above my garage door. I have some pictured attached I marked in red where...
5K
  • Locked
5K
Short Version Is it permissible to have 2 feeds to 2 separate consumer units in a detached garage? Is it permissible to run SWA underground...
