Currently reading:
Running 10mm swa
Discuss Running 10mm swa in the UK Electrical Forum area at ElectriciansForums.net
M
Mighty_G
Hi all,
I've got a 10mm cable exiting the house (on the left), and an existing 2.5mm cable running to the garage (on the right).
I want to replace the 2.5mm with 10mm swa, and have a wispa box to form the junction, questions are
Do I terminate the 10mm t&e as it exits the house into the box wispa box, or run the t&e up to existing junction box and put the wispa box there?
If I do run the swa cable from the point of exit from the house how do I get it shaped to go around the corner of the house?
Any help / advice appreciated
Sent from my SM-G903F using Tapatalk
not enough info here. Q1. what is t&amp?
Q2. why go round corner when you can bury SWA in a trecnh?
Q3. Where is the 10mm SWA being supplies from?
1. There'll be a 50 AMP MCB at the other end of the 10mm t&e
2. Cable is going to replace an existing cable run at height
3. Consumer unit inside the house
Basically the installation is a replacement of existing external t&e with SWA, but going from 2.5mm to 10mm to allow the garage to be upgraded for more workshop tools
thanks
Paul
Hi Mighty_G.
So you have discussed this change with your electrician?
Your electrician has asked you to do this change?
He is happy to sign off your work?
I'm running the cable, electrician is doing connections but he's on holiday for 2 weeks
Has your electrician done any calculations as to what size cable you actually need? has he decided on the cable run, the installation method? to be bluntly honest, the description of the install method is a bit hit and miss, not your fault as you are obviously not an Electrician.
Perhaps you could sketch out a plan of the building you are going to supply and the route to the existing consumers unit.
I can appreciate you would like to save money by doing the donkey work yourself, but in the long run I still feel you would do better by getting the entire work done by an Electrican, spend wisely as they say, good luck.
Surely, the suspension wire is anchored to the same wall as the new cable exits the house, so no need to go round the corner?
How long is the overhead run?
I'd try really hard to put this 10mm² SWA clipped to walls and underground. Overhead will always be more trouble in the future.
Hi Mighty_G.
Yup, discussed and he's happy to sign off, i've done the cabling for the internal renovation and we've worked the same way.
Basically agreed with him i'd run the SWA to the garage, this is to be in place for a couple of years until we build an extension from house to garage. But we didn't discuss the junction box location, hence the questions, however...
....good point on running from the existing wall, i was thinking of simply following the old route directly.
cheers
Paul
You'd better make sure the catenary is fixed suitably, that's a heavy bit of cable you're putting on it.
You don't want to be up a ladder in a storm trying to fix the hole in the wall where the catenary pulled half a dozen bricks out!
Good point :)
In answer to the questions on the power, there's a bandsaw, table saw, planer thicknesses and extractor, May not need as much as 50 amp but I'm putting the cable in just in case
Good point :)
You'll only be using one or two of these at any one time though right ?
Personally I would leave the 2.5 in and leave on the existing breaker.
can't see those bits of kit drawing a huge amount of power if they are all going to fit in a garage.
Mind you the earth loop of the existing may be a bit high
Hi all,
I wouldn't be terminating it into a wispa .
If the cable is running solely on the wall and on the catenary then I would be questioning if it needs to have the extra weight of metal provided by the SWA and possibly a less protected cable that would be considerably lighter would be a good idea. Just ensure UV protection.
It'd be a bit cheaper too!
I know what I'd go for, especially having seen some SWA which has suffered quite badly in the sunshine on a rooftop recently.
With careful application of the rules you could probably get the size of the overhead section of cable down a bit too.
cheers
Paul
I would really question the sense of messing around with a new cable, especially one the size you think you need, if you are going to build an extension in a couple of years......
Thanks all, advice has been excellent, going to wait for sparky to get back and discuss it further to make sure we're both happy, I feel a lot better informed now
Paul
Reply to Running 10mm swa in the UK Electrical Forum area at ElectriciansForums.net
