Discuss Running 35mm armoured overhead in the UK Electrical Forum area at ElectriciansForums.net
A farmer wants me to run a new supply to a building, it's to be run in 35mm armoured, part of the route is a 25m overhead span between buildings, is this okay for the cable or should I be getting an extra pole in the middle put in to take the weight
is going underground out of the question?
25 of 35mm SWA is going to be heavy, very heavy, as Tel asked why can't you take it underground between the two buildings? I expect like most Farmers they want a cheap job and b--ger the safety aspect. The regulations tell you the spacing for horizontal and vertical clipping etc, I would of thought that experience would tell you that the method you are talking about is IMO a no no.
How many cores in this cable? I'm asking this so that you think about the weight of the cable across the span. For example a 3 core 35mm weighs approximately 2Kg/M so this would be 50Kg. Imo this should be supported across the full length of the span using an appropriate catenary system.
A cable of that size run overhead should be fully supported and usually with heavy duty cable ladder, this would also require frequent support poles as you have to account for the weight of the ladder too and its max unsupported recommendations (at a guess every 5m) and been a farm then at a suitable height for farm plant to cross under even with any folks etc raised.
I would be seriously looking into burying this given the cost and obvious hazards having a overhead system with multiple supports would present on a farm.
Can a ladder system be fixed to the existing sheds, plus what stops you going around the sheds - a straight line isn't always possible .... just shots in the dark of course but info for us is lacking.
What about using a catenary wire. You can then cable tie it to that but like already said, try to work out the weight of the cable first.
35mm SWA on a catenary wire cable tied ,imagin that in the wind would last 5 mins , only real method for that enviroment is under ground in ducting
Oops missed that bit!!...ha ha
if there are no supports over the 25m i recon it might dislodge a brick before landing on the ground
thats only my opinion i have never used catinery wire so i honestly don't know but i recon the manufacturer's will have the recommended support distances with loadings in there paperwork
Yes it's 3 core armoured, the overhead part is not in a.through vehicle route and not possible to go underground as it's over a few smaller sheds
You need to completely redesign the whole job, it is not possible to support a cable that size on cateenery wire over that distance, a rethink, no point trying to continue down the cateenery route, just pointless.
Good advice, I agree a ladder with supports or get it in the ground.
Reply to Running 35mm armoured overhead in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I've recently bought a bungalow. It currently has a armoured cable between the house and garage which spans less than 1 meter. The height...
I'd appreciate the wisdom of the find minds here regarding this job. Yes, I've drifted into Wales again.... An extension is being planned as...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
