Discuss Running 35mm armoured overhead in the UK Electrical Forum area at ElectriciansForums.net
What about abc type cable or the old fashioned method of type 8 overhead channel iron and insulators at each end?
whatever method you decide the fixings will need to be rock solid at each end
I think the sheer cost of Ladder, post digging, bare or insulated singles wires overhead method all come with large costs, although burying it would in no doubt increase the CSA requirement you should still cost it up and ask the farmer to do the digging work if he can to keep costs low.
All methods are going to be a pain and a knock in his pocket but if that's the power he needs then he has to accept its going to be expensive.
RS do a 30mtr catenary kit that seems to carry 130kg ? and the dia. is only 3.0mm ??.Today i was looking at a catenary suspended between poles for street lighting approx 25mtr apart total run about 200mtr cable looked about a 25mm swa ? (i was driving at the time ) very little sag between poles and its been there for years.
might do it. 100m of 35mm 4c is 240kg so should work.
the problem isnt the cable but the fixings either end.
those supports have cable supports as well to keep them up usually and you will need a concrete base etc for them.
it might be cheaper to find a longer route and use a bigger cable, quick search online and 35mm 4c is £9ish a M
so thats £280 just on cable (30m)
70mm is £13pm = £390 (30m)
i bet the cost of poles and everything else will add upto a lot more than installing a bigger cable and going underground or a longer distance
An experienced Time served Electrician wouldn't consider it :icon12:
Catenary is possible, but you'd need to sink two proper telegraph poles, plus counter anchoring. He's gonna need deep pockets!
If you're going overhead, I'd also ditch the SWA and go for HO7RNF.
thats the thing it soon gets expensive, one of the biggest reasons the dno goes above surface is its cheaper than burying and making good in certain cases.
if you think about the logistics of it, it makes sence.
I've suspended 5 core 70mm HO7 over a gap of 20m before, but I was securing the catenery to solid concrete on one side, and a metallic ship hull on the other. It is easily doable, but if you're doing it at height, which I wasn't, it needs to be done properly!
Reply to Running 35mm armoured overhead in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I've recently bought a bungalow. It currently has a armoured cable between the house and garage which spans less than 1 meter. The height...
I'd appreciate the wisdom of the find minds here regarding this job. Yes, I've drifted into Wales again.... An extension is being planned as...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
