Discuss Running Ethernet cable alongside SWA. in the UK Electrical Forum area at ElectriciansForums.net
sparksburnout
Got a job where customer wants power to an outbuilding, and also wants to extend their Router down to the same building. SWA is going to be fixed to concrete posts just above ground level, and I was going to run Ethernet on same route, probably tied to SWA. Is this a good idea, and would I need shielded cable? Run is about 50M. I am not into data but I am presuming the armouring on the SWA will prevent any induction or interference problems?
Why don't you run SWA Cat5e as well, just to cover your bases. That said, I can't see it having an issue - we have all sorts of legacy data running parallel to power in the school and we haven't seen any effects in all the years I've been here.
Thanks HT I didn't realise there was such stuff to be honest! Seems like a very good idea to me.
Powerline is the easy option. If not then SWA CAT5e but if cost is too much then outdoor rated with shielding would suffice.
Depending on what kit he's running in the outbuilding you may get some harmonic distortion caused by switched mode power supplies etc which could have a negative impact on the data cable.
I am pretty sure it is just for an internet connection, its just an office for him. As I don't keep Ethernet cable in stock it might not cost him much more for me to get a custom length of SWA Cat5e.
As Murdoch has said, PowerLine adapters are great for getting you out of a pickle (I have them all over my house) but if you're pulling one cable anyway you may as well pull another and have the job done properly.
a quick look suggests 50m of SWA CAT 5 is only £90+ VAT or £2.25 + VAT per meter (TLC prices) ......... so not too bad for a pro install
Apart from strength, the armour will provide a good screen against external interference (it should be earthed) and the solid copper conductors of the twisted pairs minimise any signal degradation over the 50m. Mind you a lot of people get concerned at long cable runs forgetting the 3 miles from exchange to house which may be of significantly lower quality after years of being patched up by BT. Normal Cat5 cable is pretty weak and might easily be damaged if someone trod on the wire or hit it with a strimmer. If the customer is reluctant to pay for armoured then at least use an external duct grade having solid copper cores
A bit late to the part, sorry; but you could run a bit of fiber optic with the SWA and just use media converters at each end to turn the fiber back to Ethernet this will prevent any form of EMI from the SWA into the data line, many times have i see a bunch of data next to SWA and customers wondering why they have so many network issues !
Reply to Running Ethernet cable alongside SWA. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm going to be wiring up my garden office with power and ethernet underground and I need advice on the best way to run the cables as I have...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
I am wiring a garden room which will be a home office, customer wants wired ethernet points and wifi down there from the house router Its too far...
Hi Guys Got little bit of situation, hopefully someone can advise please..... Got an EV charger going in, groundworker has only run x1 duct. Did...
Morning, I was just looking for some advice on what other sparks would do for the following scenario:- A detached Garage is going to house a...
