Hi,
I have a s/phase submersible pump, remote float sw control, (capacitor run 20uF, capacitor start 100uF,) app 20years of age, 2in bore drawing around 6A when running on load. It has developed a problem on start up which i believe i have diagnosed and indicates that the capacitor start up relay (only 3 connections), is the culprit.
It will start after the 2nd of 3rd attempt and then run fine continuously (the capacitors test out O.K. with a capacitor meter). I am having great difficulty in sourcing a replacement relay, having tried Remco capacitors, RS, Farnell, and a pump spares company, if anyone could help with any information i should be most grateful.
thank you Griffey.
thank you Griffey.
