This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
U
underpar12
just been asked to install a s plan by a plumber.not a problem but a bit confused on how the boiler works .its a wood burner thats all the info i have ,the customer is going to use the domestic immersion htr in the summer to avoid the bolier being on , do i treat it as a normal boiler and supply a live supply from my wireing centre.:confused:s
I do a lot of boiler work, but cant think how the SW fromthe valves etc would start the boiler. What type of boiler is it?
the ones i have done are simular to an old back boiler burning the wood heats up the water and the programmer provides the supply to the zone valves and pump , there is no switch feed to the burner as its not required may be wrong though but these were the ones i connected
Supply from clock (if used) to R/S to valve to pump.. No supply to boiler. The boiler heats the water as a store, the heating takes it from the store via the valve.
