Discuss Sangamo timer clock not working in the UK Electrical Forum area at ElectriciansForums.net
rolyberkin
What Tel said. And there is sometimes a red over ride button on the side wich will bypass the clock. Wich might assist you in fault finding.
The emergency lighting should be on a pernament supply and not off the switched side of the timer.
The solar clocks are a cool design, unfortunately the newer ones have a battery backup, the battery often leaks all over the PCB after a few years, destroying the circuitry.
Reply to Sangamo timer clock not working in the UK Electrical Forum area at ElectriciansForums.net
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi, I want to wire in a timer switch to a bathroom extractor fan. The extractor fan is currently wired to the light switch or more specifically...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
