Hi, anyone know if a Schneider Easy9 Mainswitch & RCBO's will fit in a Acti9 board ? The Acti9 board in question is fitted in a single ph domestic dwelling and I want to swap out the existing mainswitch RCCB with a 100a switch which is Easy9 fare. Similarly will Easy9 RCBO's fit an Acti9 board ? Anyone know ? Ive emailed and called Schneider tech support with no response. Thanks
HI Eric did you find out? I'd like to know the same
I found Schneider to be unusually helpful with technical queries; I asked them if they had a Type A RCCB that was compatible with an old Domae DB. They replied within a day offering 2 models (63A or 100A), with part numbers, and an attached PDF "Statement of Backwards Compatibility". I was pretty impressed!
I contacted them through a form on their website, after that it was all via email.
Pretty sure this is where the form is: Contact UK Customer Support - https://www.se.com/uk/en/work/support/customer-care/contact-schneider-electric.jsp
Thanks for the tip, I got in touch one evening and they replied a few hours later at 2am apologising for the delay!
They confirmed that as suspected, the Easy9 devices do not fit in the Acti9 boards
London
United Kingdom
Schneider Easy9 in Acti9 board
Eric12,
sylvn86,
