Discuss Sealing with Silicone Sealant in the Australia area at ElectriciansForums.net
DanBrown
Can anyone confirm whether you can seal using silicone sealant where cables are in contact?, ive been told by my electrician im training with, that this is not allowed as it causes the cables to de-grade..
Agre with the J man there. I've used it many times in the past and ahve never had any problems with it.
Has anyone ever used the Magic-Gel sealant, awesome it is.
Think he maybe confusing silicone sealent with expanding foam or some of the older intumescent fire sealent, these contain ingredients that can break down the pvc of cables.
Mark
the magic gel looks good stuff i have used the pirelli compoud for years never any problem
with it but might just give the gel a go do most wholesalers stock it
Hi guys, there is creosote in the PVC sheathing to make it more flexible. the chemicals in the silicone sealant react with this drawing it out of the PVC making it go hard and brittle
I agreee - Do NOT use silicone. I just dug up 2 sealed conduit boxes I had sealed with a top grade silicone. The insulation resistance had caused the breaker to keep tripping. When I opened it up there was moisture around the cables, which had hydroscopially crept right up to the joint.
Even the crimp on connectors had rotted. - It's a lot more expensive, but Magic Gel is the thing to use as a potting compound.
QUOTE=dazza69;34372]Hi guys, there is creosote in the PVC sheathing to make it more flexible. the chemicals in the silicone sealant react with this drawing it out of the PVC making it go hard and brittle[/QUOTE]
As I understand it, there USED to be an issue with certain chemicals causing degradation to the particular PVC recipe used for cables, however it was only ever for a couple of cable makers and they have long since changed the recipes they use. Therefore, in 2012 there should be no issues. BUT....there's silicone and then there's cheap sealers that pretend to be silicone..... so you get what you pay for.
This is also similar to the old tales about how mice love cable because the older stuff used sugar as a constituent. The truth is out there somewhere.
******* EDIT **********
Just seen the original date on this thread!!! Why has someone gone dragging it up???????????!!
Sir, sir
It was that new boy Gyhllwood. Shall I take him to the prefects?
Reply to Sealing with Silicone Sealant in the Australia area at ElectriciansForums.net
Hi. I live in an older house and I have old white twin and earth cables going through walls in large white pipes. Unfortunately, some mice managed...
Holes in meter box near cables. Can you seal them using expanding foam or silicone sealant? Do they damage cables?
Hi, I inspect homes for safety as part of my job. I saw this junction box in a splash zone above a wash basin, it's next to a shower/steam unit...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
