Discuss Seaward Europa Plus compatible printers in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I have a Seaward Europa Plus tester & a Kroy 3100 printer & want to replace the Kroy as it's done a lot of tags & i'm looking for something like the Test n Tag Pro, its light, prints fast & labels are reasonably priced but I don't think its compatible, I know the TnT Pro is made by Able Systems in Northwich, it's a model Ap1310LP but I don't know if it's plug & play, can anybody help with this printer or any other that might do the job
Thanks a lot
Speak to Seaward perhaps?
Greetings Ristead, thanks for your reply, good idea, I'll send them an email today today, may be just a firmware up date on the TnT Pro . I've had a look at their website but it only mentions one printer as being compatible;the Desk Test n Tag, however it weighs 2.8 KG & needs 240 v power, while the TnT Pro weighs only 446 grams and is battery operated,more like what i'm after.
(Barry) John
PS In passing I noticed you are based in Derry, my original families the Callaghans & the Kennedys lived in County Derry & my cousin tells me we still have rele's there
(Barry) John
No problem at all.
Whereabouts in the county are your relatives?
Reply to Seaward Europa Plus compatible printers in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Replacing a fan and some lights today at a job I'll be doing more work on, which has an "Emma" branded consumer unit. Googling suggests that it's...
6K
HI Folks. This is my first post so apologies if it's in the wrong location. I recently installed a 3kw Solar system with an iboost diverter...
5K
Is there a room in professional PAT testing for a business model other than 'per unit'? I ask because I've been giving this some thought. I've...
9K
Hi Does anyone know of any decent printers that are compatible with the Seaward Europa Plus. At present I use the K3300 that was supplied with...
E
Hi, I have Seaward Europa Plus and a few days at startup displays the following message: Attention It is recommended that your europa is due for a...
