Discuss Seeking advice on quote to replace CU in the UK Electrical Forum area at ElectriciansForums.net
Don't think I've ever come across a DP RCBO, but a DP MCB has a current sensing element in each pole, and usually consists of two SP MCBs rivetted together with a link between the toggles. A SP & N MCB has a current sensing element in the live pole and just a switch in the neutral.
If the RCBO in question was used on a split phase supply, the RCD element would still work on both poles (unless there was an equal leak to earth on each phase), but one of the phases would not have any overload or short circuit protection.
I remember a discussion from some time back, in which it was discovered that certain 'DP' (2 module) RCBOs were also SPSN.
To be honest we probably aren't doing a lot to help the OP ask a clear question of his electrician!
The point is that when you turn the thing off (or it trips) both Line and Neutral are broken so the circuit is completely isolated and any faults can't cause issues elsewhere. While the learned people are right, to be honest "double pole" is probably the term that is most likely to be instantly understood by the average domestic sparks.
CEF call the Lewden RCBOs "single pole" vs "single pole and neutral", the latter being the one's that would be best to use.
(to add to the confusion Fusebox SPN units do not break the Neutral and they call the one's that do DP ....!)
Electronic type
• Residual current characteristic: AC
• No of poles: 2 (L and N)
• Trip curves: B and C
• Rated voltage: 240V AC, 50/60Hz
• Short circuit capacity: 10kA
• Rated current (A): 6, 10, 16, 20, 25, 32, 40, 50, 63
• Rated residual operating current, In (mA): 30
• Electrical endurance: 4000 cycles
• Mechanical endurance: 10000 cycles
• Conforms to: IEC/EN 610009-1
Reply to Seeking advice on quote to replace CU in the UK Electrical Forum area at ElectriciansForums.net
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
