Discuss Seeking some advice following am2 results in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Good evening,
So I have recently sat my am2 and just received my results. I passed with the installation, theory, fault finding etc but failed on the testing due an issue with insulation resistance and also the initial safe isolation section. I can only think that I didn't carry out all the necessary steps in the isolation. Procduere.
Anyway I understand I will need to re take the testing section but I was told if you fail the safe isolation section you need to retake it all (a previous participant told me this) 0just wondering surely this cannot be correct and hopefully I just need to re do the safe isolation and testing.
Anyway sorry to ramble on its just got me slightly stressed
Any responses are much appreciated
I honestly don't know about having to re-sit the whole thing for failing on safe isolation but it is arguably the most important part of the test.
To be fair if you passed everything once it should be easier second time around so there really is nothing to stress about.
To practice safe isolation at home until it's second nature you could draw some dots on a piece of paper and have a cheap padlock to hand.
Use probes or pencils until it's built in to your muscle memory. That way stress should not get in the way of you getting it right.
If having to resit an exam is the worst thing that happens to you then you are doing well in life. :)
Good luck on the retest.
I nearly failed my C&G inspection & test on the isolation part - I left the key in the padlock which I'd locked off the main isolator with. Luckily the assessor was decent about it and gave a little cough, which made me double check things!
Only the Centre who tested you can confirm if you need to re-take the lot.
It may be at their discretion, it may be the certifying body.
Good evening,
Was it the A1 safe Isolation section you failed? If thats the case I have heard that the college actually shouldnt let you proceed with the build as the board isnt safe and that if you fail that bit you have to retake all of section A including the build as safety is the core part of electrical work. If they let you proceed with the build having failed it I would contact the college and query why this was the case as the board wasnt safe to work on having not been isolated safely. May give you some leeway to negotiate how much you retake or the cost.
If you fail an section then you have to resit that section. If you fail the first section (A1) initial verification, you can continue with your install and the rest of the assessment. You would just have to go back and revisit the safe isolation A1 section again.
That being said, if you fail the install then you have to revisit the install plus the A1 safe isolation section.
[automerge]1577355947[/automerge]
Sorry I should have said, you also have to do the risk assessment again which is part of the A1 safe isolation.
Can anyone help i finished my am2 Wednesday morning I know it says up to 5 working days for results but did anyone get them before hand and if so how long cheers. Gav
Source URL: Hi new to the group and after advice. - https://www.electriciansforums.net/threads/hi-new-to-the-group-and-after-advice.187215/
From memory I did mine Monday to Wednesday and recieved the results early Friday morning. But it is entirely dependant on who you sat the exam with. I've heard of results taking over a week.
Reply to Seeking some advice following am2 results in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi all, hoping for some advice, I’ve recent resit my AM2s after failing on first attempt… I’ve passed all my resit apart from section C just on...
Hey all, First post but have read up a lot over the last few months as I have been prepping for my AM2s which I sat last week and thought I done...
Hi everyone, Did a resit on safe isolation (a1) first thing Monday morning I know safe isolation I feel a n**head lol just wondering if any one...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
