Discuss Sense check on Nest / Worcester Bosch 280 wiring in the Central Heating Systems area at ElectriciansForums.net
N
Neil Potter
I’m looking to self install a Nest Learning Thermostat on my Worcester Bosch 280 boiler, mainly as it’s a rented house, and I need to be able to remove the Nest when I leave, or when the boiler is serviced.
The wiring looks straight forward, but I just wanted to sense check before I go ahead.
The boiler doesn’t have a stat currently, so on the stat section has an unused N connection. 1 & 2 are jumpered (2 shows 240v, 1 is 0v), a 3 is unsued and unmarked, and 4 is unused and marked Frost Stat.
So I assume I can run a 4 core to the Nest Heatlink, and wire up as follows.
N from boiler to N on heatlink
2 (240v Live) from boiler to L on heatlink, and then jumper L on the heatlink to common / 2 on the heatlink (do I need to run a 3A inline fuse or not on the jumper cable?)
1 from boiler to 3 (relay open) on the Heatlink
Earth (needed or not? As Nest stat will be wireless)
Is that pretty much it, bar testing, tidying, and testing again?
Reply to Sense check on Nest / Worcester Bosch 280 wiring in the Central Heating Systems area at ElectriciansForums.net
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I have a Worcester 28CDi combi-boiler witted with a wireless thermostat which has stopped working. The model numbers are: Receiver 7716 192 005...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
We've just bought a house with Maincor underfloor heating with programmable room stats. I'd like to change these to nest stats so I can have...
