N
Neil Potter
I’m looking to self install a Nest Learning Thermostat on my Worcester Bosch 280 boiler, mainly as it’s a rented house, and I need to be able to remove the Nest when I leave, or when the boiler is serviced.
The wiring looks straight forward, but I just wanted to sense check before I go ahead.
The boiler doesn’t have a stat currently, so on the stat section has an unused N connection. 1 & 2 are jumpered (2 shows 240v, 1 is 0v), a 3 is unsued and unmarked, and 4 is unused and marked Frost Stat.
So I assume I can run a 4 core to the Nest Heatlink, and wire up as follows.
N from boiler to N on heatlink
2 (240v Live) from boiler to L on heatlink, and then jumper L on the heatlink to common / 2 on the heatlink (do I need to run a 3A inline fuse or not on the jumper cable?)
1 from boiler to 3 (relay open) on the Heatlink
Earth (needed or not? As Nest stat will be wireless)
Is that pretty much it, bar testing, tidying, and testing again?
are you a spark .
rented out you say , have got a liability insurance. if not get some body in .
Do you have permission from your landlord to do this?
What controls are currently installed?
Are you suitably qualified to open the boiler casing?
Sense check on Nest / Worcester Bosch 280 wiring
Central Heating Systems
Neil Potter,
davesparks,
