W
weyland
Hello everyone. I would like to know how many second we need to set on timer to change the star contactor to delta contactor. Is it depend on motor rating. let's say i have 10hp motor. so how many second should i set on timer? Thanks
It’s a case of suck it and see, as Paul said the change over needs to be about 80% of the running speed.
maybe different hp of motor have different time set. there must have a formula for it.
Will probably get shot down in flames for tis post , but hey ho !
I always set them by ear , once it sounds just about run up then that is where i set it .:behead:
I've always clamped a line, started the motor and set to timer to when the amps start to drop after peak.
