Discuss Short circuits calculator (IEC 60909) for Android in the UK Electrical Forum area at ElectriciansForums.net
Friends, I need help with my app testing.
Can I put my app link (Google Play) here?
Free, no ads.
This application (fault currents and voltages calculator) can be used for the following calculations:
- three-phase fault current (IEC 60909);
- two-phase without earth connection fault current (IEC 60909);
- two-phase with earth connection fault current (IEC 60909);
- phase to earth connection current (IEC 60909);
- total fault current (IEC 60909);
- positive sequence fault current (IEC 60909);
- negative sequence fault current (IEC 60909);
- zero sequence fault current (IEC 60909);
- three-phase fault voltage;
- two-phase without earth connection fault voltage;
- two-phase with earth connection fault voltage;
- phase to earth connection voltage;
- total fault voltage;
- positive sequence fault voltage;
- negative sequence fault voltage;
- zero sequence fault voltage.
Thank you for help!
Reply to Short circuits calculator (IEC 60909) for Android in the UK Electrical Forum area at ElectriciansForums.net
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
Hi guys I was recently ask by a customer if/how his house could be supplied by his electric car. He wants to charge the car at night on low rate...
