Discuss Show your insulated tools in the Electrical Tools and Products area at ElectriciansForums.net
Hi everybody, i want to show my insulated tools and i would like to see yours,my tool are Facom. Knipex and Cimco.
I somehow feel mine do not match up, Aldi and B&Q:angel_smile:
However I am not sure I would have a use for the wide range you have there.
Though I would like a set of insulated long nose pliers where the blades are also insulated.
My Aldi screwdrivers were doing well until I snapped a flat head - had to repair it though and it's back in the set as a pry bar or chisel! Irazola took its place in the pouch but I still have a soft spot for that original!
Sent from my iPhone using Tapatalk
Mr Burns, is that a snapped pair of side cutters - is there a story behind that?
. . . and what lesson did we learn? - and it's not borrow someone else's cutters!
I'm curious as to what sector the OP is working in that his company has found it necessary to issue that amount of insulated tools!
He might just be clumsy so his firm are covering all bases :oops:
Guessing a cable jointer ? hmm which colour spanner are we using today maybe the orange one.
Nice set of insulated tools never seen a complete or new set like that also guessing a new job?
Have any of them been used? None of mine look like that!
Presumably they have been used, but if they were not clean and with no visible damage on them then they would not be permitted to be used as the insulation rating could be compromised.
Obviously it is all down to the company's risk assessments and method statements/codes of practice but insulated tools for live working will generally need to be clean and undamaged with regular inspections and testing
Obviously it is all down to the company's risk assessments and method statements/codes of practice but insulated tools working will generally need to be clean and undamaged with regular inspections and testing
I agree with you again.
I've altered the quote a little, and I think that principle should be applied to all tools
I agree that they would eyed to be undamaged and regularly inspected but I've been working with dno's for years and never seen a guys tools looking in that mint condition. a couple of mine are in that good nick but not all.
Like this:
Knipex 98 62 02 VDE Insulated Snipe Long Nose Plastic Pliers 220mm Fuse Pulling | eBay
I've bought some Knipex stuff from this seller without a problem.
Yeah gave to agree, this guy xpn1 on ebay is good and have also used him a lot
Yeah that's the kiddies, wonderful for doing such terribly naughty things as disconnecting or connecting a single circuit in a live DB. Also very good for generally manipulating cables in a small enclosure due to them being a little softer in their grip on the insulation.
Well the collection is looking a bit better, thank you. (but my wallet is not:sad3:).
Selection is now Aldi, B&Q, random ebay seller :stuart:(with recommendation)
I hope you're not planning to do terribly naughty things now - just because davesparks does!
You are a breed apart - you pyro boys, one day we'll all get to 'light the blue touch paper and retire' but this government probably won't let it happen until we are 85!
Sent from my iPad using Tapatalk
My tools
Pliers are Schneider
Side cutters Knipex
Screw drivers are a mix of Bahco, Draper. My most used driver is 4mm x 100mm is CK with a cheap backup bought from Screwfix.
Long nose pliers bought from Wickes
My pliers used to be Knipex but they were borrowed by an electrician when I was testing for Schneider so my site contact replaced them.
I have a hotch potch of VDE tools. I have a set of 1KV screwdrivers made by 'Futur' or at least that's what's printed on the handle. They were cheap even though they came from somewhere on the spice route (about 15 quid for the set) but have actually lasted very well. Apart from them I splashed out on Knipex VDE side cutters and long nose pliers, a no-name VDE adjustable spanner and a few VDE allen keys for common MCCB and ACB terminals. Not sure if my gloves, apron and Ex rated flashlight count as VDE.
Don't mind me while I bump some old threads. Just doing the rounds. Ignore the thread if it's not current topic, it'll soon drop off the list, but if the thread interests you, feel free to reply. :)
Reply to Show your insulated tools in the Electrical Tools and Products area at ElectriciansForums.net
Hi All. Hoping for some advice please. I've severe arthritis in the hands (all three :flushed:) A large dollop of osteoarthritis but I'm also...
As I have retired now (really!) I have decided to sell my electrical tools etc. They include hand tools, hilmor galv. conduit bender 20/32 with...
Hi. Quick question, tightening torque for 25mm 6491x meter tails into a Henley block, anyone know or would it most likely be just FT? The Henley...
Inspired by another thread, which I don't wish hi-jack. Can anyone recommend a decent, relatively low price punch down tool? I've had a cheap...
Hi Guys Think it's time I brought myself a 'decent' punch down tool. Any recommendations would be appreciated ? Been eyeing up both of...
