- Sep 23, 2012
- 398
- 185
- 1,218
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Electrical Engineer (Qualified)
ok so if i install a cable above the insulation and everything is ok and then they come along and top up the fibreglass in the attic space as is common place now and i had used 6mm cable where do the regs stand on this ? if someone else changes the shower for a larger one and does not bother checking anything what does the regs say ? nothing i have my reasons for the things i do i do my own thinking in the original post there was no cable length no fixing method so i gave my honest opinion as i would to anyone i will not make any apologies for trying to make sure i give the best information for safety i think i can give and as stated i did state that its just me!
