Discuss simple yet confusing light fitting change in the DIY Electrical Advice area at ElectriciansForums.net
W
williams83
Sorry if this is in the wrong section, but I'm having a right mare with a new light fitting.
Forgive me if I'm being stupid but this is confusing me. (Possibly something simple)
So I have purchased a new light fitting to install (not usually a problem). However when taking off the old ceiling rose I have noticed three incoming cables. These are looped and feed the lounge and hallway.
I have 2 black/neutral, (into neutral) 3 red/live (into loop) and 4 earth. Nothing labelled as switch live. Two are standarf T&E, but the other has 1 live and 2 earth ?
On the new light fitting I have the normal L,N,E into connection blocks.
Based on wiring the new light how the old one was, I cannot get them to work.
Can someone advise the error?
Thanks I'm advance.
identify the switch cable using a meter set on ohms. then work it out .
the one with 2 earths may be a twin and earth with insulation messed up.
It's a new property I've just brought so didn't have a meter to hand.
The thing is, 3 lives were looped, two neutrals are in with the Neutral but there isn't a neutral/switch live. Looks as though there is a neutral missing, and the fact u have one imcoming with 2 earth's and and live is the confusing part.
The picture below is exactly how I removed the light (left) and how I wired the new light (right) only difference being the layout is like for like minus the switch live.
The diagram above is correct for a standard wiring scheme but with lighting there's numerous variations that can occur so your wiring may be different. You're going to have to manually identify each cable and wire and work out the correct connections from there but without test equipment it's not going to be something you can do yourself. I'd strongly suggest it's a job you'd be better getting a sparky to help you out. If it all worked fine originally and you've not disturbed to upstream or downstream wiring it should only take s short time to sort it out with the right test equipment.
OK thanks all for the reply. I'm just a trainee at the moment. However have spoken to a more qualified electrician that will assist with the correct tools.
Reply to simple yet confusing light fitting change in the DIY Electrical Advice area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
i know about the different wiring arrangements for 2 way light switching. i want to connect the permanent live into first switch common, connect...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
