Discuss single front end rcd in the Australia area at ElectriciansForums.net
B
Brilec
Hi Guys, new to forum, so may already have been talked about before, have ajob to quote for 2 bed bungalow, old wire fuses, 4 in total, 1 cooker, 1 ring main, 1 lights and 1 immersion heater, how do I fit rcd sytem to such a small system without going overboard for the customer. before hand a rcd main stitch would probably been ok but with current regs would not allow power to remain if one item tripped out the lot, have thought about rcbos but adds alot to the price, would like some suggestions
I try to push for dual rcd boards with en 60898 devices, If the system is old with 1mm cpc in ring and 3036 fuses may not meet disconnections times also check carefully that the lighting cct has a cpc in all parts.
Best to PIR the existing instllation also
ask your wholesaler about europa i`ve done a few c/u changes using these and never had any problems. useually find europa rcbo`s are about £12 each. anyone know anybetter then let me know.
i`m always interested in a bargain
Reply to single front end rcd in the Australia area at ElectriciansForums.net
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hello, I am hoping this is in the correct forum. To start, I acquired a film processing machine that runs on 3 phase. Now before getting the...
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
