S
sparc
I have a run to a 9.5kW shower. Prefer not to disturb the ceiling (flat roof above) and am thinking about using mini-trunking round tops of walls, then down to shower.
Small mini-trunking would be great, but I know I'm going to have fun with 10mm T&E in small trunking - so I'm wondering whether I could use singles instead. I don't see any reason why not from the regs.
It's only about a 12m run, so to save cost I'm thinking of using some existing 10mm T&E I have - strip that down to get the L and N singles, then buy some 6mm CPC insulated single.
As far as I know there's no difference between the 10mm insulated conductor inside a piece 10mm T&E, and a 10mm single.
Anyone see any flaws in the plan to use mini-trunking for singles - or stripping T&E to get a single? Or should I bite the bullet and put the T&E through the ceiling?
(Cable is coming off a 40A mcb on 30mA RCD, by the way, and shower feed is nicely bonded up.)
