Discuss skeleton consumer unit in the UK Electrical Forum area at ElectriciansForums.net
W
Welshsparky
Went to price a cu change this morning, can anybody advise me were to find something similar to this but an rcd version? ive never come across anything like this one before... Is it going to be an arse to replace?!
Hard to make much out from that photo. Has that one been taken apart and bodged in there? Without knowing the size, or seeing it first hand, could you make a flush mount board fit in there somehow?
i had a similar thing in 2 flats that i rewired, i removed all the guts and fitted a new board over the existing box, then brought the cables in thro the back entry(singles in conduit)
I would go through your consultation process,IR tests,Continuity tests etc.Does your client require any extra circuits.when you know everything about installation,ie are the new RCDs going to hold,i would rip the lot out and put a nice shiny new 17th edition board in
Well a size ie how wide how high would help 2 things here you could put a 17th CU mounted on its side or depending how wide you coulod buy an standard 8 way board and fit RCBOs
This is not a lecture but just a bit advice when you look at jobs like this you need to gather as much info as you can ie high wide circuit entry top ,bottom,side ,Ze,PFC,PSSC,and some random Zs readings put all this together and you can get a better idea
All of that is removable I did one a couple of months ago and did a fair few a couple of years ago , it's all just bolted together , so get you socket set out and then your left with a meter box to house your 17th edition board!!
As Lenny has stated, additionally Crabtree also do Skeleton replacement RCD cu for these Mantel recessed cabinets.
Those 2 T&E cable's aren't original, as well as looking like being installed by bodge & hoppit !! In fact they have been installed within the DNO designated area of these cabinets. Where is the meter anyway?? lol!!!
Reply to skeleton consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hello all.. I'm quoting for some work and would like change the type AC RCBO to a type A. Consumer unit is a castlec which I have not come...
