Discuss Small commercial laundry re-wire in the Commercial Electrical Advice area at ElectriciansForums.net
Hi there,
We have a small commercial laundry which we're told need to be re-wired. There is an old 3phase 3036 fused board and wiring in metal conduit.
We've been told that the switches etc should be IP rated but it most just a damp atmosphere rather than things getting really wet. What IP rated should we be looking at for switches etc?
The other things I'm not clear about is, each machine, like the 3 phase washing machine, has it's own fuses in the DB but also has a fused isolator fused at the small rating as in the main DB, Do we need fused isolators if we're moving to a MCB/RCBO phase DB or can we use IP Rated 3 phase rotary isolators?
Sorry if these seem simple questions, just trying to get my head round things so I have some idea of what I'm looking at.
Reply to Small commercial laundry re-wire in the Commercial Electrical Advice area at ElectriciansForums.net
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
