pc1966
Well today I finally got round to visiting parents to fit an interlinked alarm system as new Scottish government rules dictate (a whole separate "discussion" there). Managed to get some Aico wireless ones including a remote unit but one smoke short of complete system due to current shortages so decided to put in just upper hall/landing and both bedroom, instead of both landings and only one bedroom for now.
Removed 3 old alarms, two dated from 2000, one from 2009.
All 3 missing their PP3 batteries FFS!
Did you get the heat detector for the kitchen ok?
That’s what’s been short in all my suppliers. (603rf)
Actually, @pc1966 if you’ve gone with the aico 650rf units, with the long life battery and Radiolink… you’ll have to take them down to house code them with any additional ones you put up.
Yes, those units. That was my hope, ideally just getting the control unit to initiate it but never done that before. But not sure if you have to get all in to the new house code state but button pushing, or it can be kicked off centrally?
What I do is press and hold the button on the rf module until the blue light flashes continuously… I do that on all the detectors before I screw them up.
They stay like that for 45 minutes I think, as they all pair up together.
Yes, got that done for the units I had, though one heat alarm needed the RF module unplugged and properly re-seated before it connected OK. Took 30min for them to return to normal.
What I am less sure about is re-entering the pairing-up state for adding another, if that can be done by the button on the remote or if I have to get all of them off again to start as if new.
I think you have to take them all down and do it again.
No expert in the inner workings, but I think while the blue light flashes, the radio modules go through frequencies or patterns of signal to find the best signal for that particular house.
They must work around possible cross talk with other detectors next door perhaps.
OK, it is not a big deal to get the ladders out. Their home (Victorian era) has around 10 foot high ceilings down stairs so it is not easy by any other means!
