hi guys need a bit of insight here. Wiring up mains smoke alarms and interlinking with heat detector in property. Came across a bit of a grey area with legislation. Now I know it can be wired on its own circuit or on with an existing lighting circuit but I can't find anything telling me if the supply to the first smoke alarm has to be wired from the lighting circuit breaker at consumer unit or if I can tap off a light/switch with a permanent live and neutral. Will make a big difference as the cu is a nightmare to get cables to!! Any help will be much appreciated. Cheers
