Think you may get away with it but id rather stay on the edge of better to be safe than sorry. Blank it, with some maintenance free connectors.
Nobody can plug something in to it, drop it in the sink and you would have to prove why you left it while being dragged through courts.
Ive had issues with tennants before they always seem to win. especialy when it comes to safety, when you could of made it safer! (with the council getting involved...umm...)
Due to the height of the socket I think it is totally fine up there looking down at everyone.. as long as it isn’t exceeding the maximum installation altitude of 2000m
It's probably best to keep socket-outlets below 6,500 feet alright.
Reactions: sibbits and Strima
  • Funny
Reactions: DPG and Spoon
Annoy the tenant and put a smaller sink and drainer in without that small bowl. Reckon there's 300mm between the socket and the main bowl.
Funny you should mention this. I've had to redesign what VSDs I am using on a job in Albuquerque as the city is around 6000ft above sea level. (Higher than Ben Nevis anyway)
Many manufactures have de rating factors on components once you get over around 2000ft above sea level.
Not that this is ever really applicable in the UK.
I have a toaster from a major manufacturer which has a lead on it of 90cm. So if the socket was over 300mm away from the sink say 400mm, would this make it any safer? #justsaying!
I don’t think that measurement is there to prevent stuff being chucked in the sink but to prevent the accessory from being excessively splashed with water
  • Funny
Reactions: rolyberkin
Oldish thread I know.
Going by the electricians guide to the building regs - what with the adjacent hob, you're never going to get a socket on that wall.
I generally stick to the 300mm guidance for hobs and sinks, but in this instance as per the image, there's not a lot else could be done. A kitchen needs to be functional and practical.
Reactions: Jurassic Sparks
From the guide
Reactions: stevethesparks
blank it or turn sink through 90 degrees so it's under window. benefit of more worktop space FOC, :):):)
My issue with this is that the guides states that no socket shall be installed above an electric or gas hob yet there is no mention of above a sink. Obviously no one designing an install would put a socket above either but what if a socket was over 300mm above the sink. Technically it would then be 300mm away from the sink edge. I realise the diagram show adjacent to, but I'm just imagining the scenario being played out in a court of law with some fancy lawyer picking up on the lack of defined detail.
A mate of mine with a rental property had a tenant who called him out 3 times because the lamp in out outside light failed. On the first two occasions he explained that lamp breakage was the tenants responsibility... on the the 3rd occasion he just took the light off. No more call outs.
Reactions: telectrix
Remove all 'Safety Socket Covers' from every socket. Check to see that they haven't damaged the sockets.
Lots of organisations have banned these, as they can be dangerous.
I honestly don't get why these aren't just banned outright, complete legislative ban i.e. criminal to supply or use. They're a PITFA, I get the argument for them but the sockets should be intrinsically safe as per standard.
S
9K
Australia
SparkyDips
S
Socket near sink, to blank or not to blank!
Thread Tags
steve-ef,
Lister1987,
