Discuss Sockets arcing - baby socket protectors? in the UK Electrical Forum area at ElectriciansForums.net
I was called to a house today where the home owner had experienced arcing (enough to cause scorching on outside of socket) on 3 sockets on the same ring with 3 different appliances causing the MCB to trip on each occasion. I took socket fronts off - no loose connection, continuity good on ring, earth loop good and rcd tested.
I was puzzled. I did think that maybe the baby socket protectors which were in each socket could possibly have something to do with it as I have heard they can cause socket front damage and was wondering if anyone else had come across anything similar?
the cover for the plug pin will not cause scorching ,but appliance might, a wall heater drawing to much current .
Hi thanks for reply. I think the scorch was caused when he removed baby socket protector and went to plug in another appliance.
You sometimes get a snowball effect where one plug has an arcing fault and that damaged plug then gets plugged into other sockets which in turn get arc damaged and they then cause damage to other plugs that are used in them....and so on. Before you know it's spread like measels through an anti-vaxers family and you've got several damaged plugs and sockets all in the same vicinity.
Reply to Sockets arcing - baby socket protectors? in the UK Electrical Forum area at ElectriciansForums.net
Slightly strange one this, replaced a few socket fronts in a dining room today, all wiring original but new plasterboard on a studded wall. Its a...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
  • Locked
5K
