Can you actually prove by using the current laws of the known Universe that God does or does not exist?... ;)
I once pulled a 9/10 bird (yes once) when i was 18 much to the dismay and anger of my friends.
Conclusion, god must exist because she was a godess and i can still picture it now.
Note: history from computer being erased before the other half finds this and i have a vocal range greater than a 10year old girl.
you wouldnt need to prove god exists lol , the installation designer will get the full brunt of any legal action following an incident.
which leads to the question , why the hell do you needs sockets 1 mtr from a baptism pool ?
no-ones gonna be recharging their ipad during little jonnys christening lol.
bad design defended badly by the designer.
Well its one big basin for sure. I would be onto the "experts" for back up. In this case get a written statement from NIC or Napit etc after providing the drawing of what is proposed.
You can picture 'it' now...............or her
:smilielol5:
I pray the answer to the existence of god is not made to be dependant on the position of the sockets in the water dunking arena.
I'm hoping no-one dyslexic is reading this or they'll be wondering why the dog is looking for apples in your pockets:6:
that's what i think also andy its a pool end of story, its an evangelical church allan at the last site meeting i was tempted to ask the client if there planning to all get in and chuck a toaster in and see who gets 'chosen' to cross over but the sockets are for a heater which has a plug top and is then submerged into water and removed when water reaches tempurature, also to the side of stage there is a i/o unit for audio equipment for the church band so sockets for musical equipment. i have my annual nic inspection on thursday so will definetly be discussing with him, its intersting looks like there's a bit of mixed opinion
thanks mark
What sort of water heaters are they planning on using to heat this water?? lol!!
I think you'll find that section 7 of BS 7671 will almost certainly APPLY to this baptism pool. As for using portable immersed water heater(s) to heat this body of water, beggars belief to be honest, especially on a new build. I would have thought a circulating boiler system of some description would have been a far better design route to take. A (2m x 4m x 1m) basin is going to hold a fair ole volume of water!! lol!!
On a serious note, holy intervention will not revoke you’re duty of responsibility.
You know it’s wrong, you are duty bound to stop this lunacy.
Think the designer has this one wrong he's just being stubbin not listening to you which is daft none of us now it all and if we make mistakes yes even designers do this your better of listening and not making the mistake again stick to your guns he's wrong
Look at it this way: If you went to see a job at a big house where some rich guy had built a 2m x 4m x 1m paddling pool and he wanted sockets fitted 1 meter away from the pool cause "the sockets are for a heater which has a plug top and is then submerged into water and removed when water reaches temperature." you would just laugh at him and walk away..
It's a pool, it is a special location, ignore the designer they are not the person who will end up in prison - you will if someone dies from a shock.
Are you sure the designer only wants 13A sockets. Something just doesn't ring true when they are going to use a plug in immersion type heater to heat at what I can best guess is around 1400 gallons of water given the size of the pool are they using multiple heaters and what rating are they
As the size of this pool suggests that full immersion baptisms will be done how can the designer be so certain that no water will be splashed!!
To the OP I think you really need to cover your rear end with this one
As there is a designer involved I assume he is the one that is signing off the design part on the installation certificate, I would also keep a chronological record of all conversations and written instructions with the designer and architect and also all the job drawings as I can only see this going legal at some point
This one of those posts that starts to look like a wind up when you start thinking about it a bit more as something doesn't stack up in this design
The designer may be arguing his point quite fiercely now,but if someone gets hurt he'll do a u turn faster than David Cameron.
