Sounds like a dead short to me.. wire come loose somewhere? - this is why I prefer to do the R1R2 test after the socket is screwed back into its box with an adapter plugged in (or dont take fascia out in the first place).. then the wiring isnt disturbed after testing.
hi there i need a bit of help basically the rcd trips and the shower mcb trips the same time. then its ok for a day then it randomly does it during the night etc even when the shower isnt in use, any ideas?
look in the switch for starters, esp. if it's a pull cord. then usual continuity and IR tests with the cables dissed in the shower.
