Hi, I have a holiday apartment in Spain, very near to the sea so very humid atmosphere.
Wiring is 40 years old, radial with two large boxes with lots of choc block connectors.
Eight years ago I had some problems and replaced several overheated connectors, I used the best quality connectors I could source, the wire cores were mostly tarnished which I scrapped off before connecting.
Recently had similar problems and had to replace several more.i have used silicon spray this time to try and reduce corrosion. Main breaker is only 25amps so at times power usage is near to maximum. Any ideas why this is happening and are better connectors I could use, I can always bring some from the UK.
Please see attached photos.
Many thanks in advance for any comments.
