E
Engineer54
as far as i'm aware , concentric cable was developed for use by the dno's for their cut-out tails because its alot cheaper than swa and can be worked on live alot easier than swa.
They also don't need to terminate to the degree that you will in there service cut-out, the earth strands (TN-S) remain bare, just twisted together and semi dressed to connect into the internal terminal block, or heat shrinked where they run external to the MET....
