Discuss Star Delta starter Fault... in the UK Electrical Forum area at ElectriciansForums.net
C
csaw2121
As part of my oral exam (oo err!) for my marine engineer license we get asked electrical questions.One such question that's been asked is " What would happen if a Star Delta Starter didn't change over and continued to run in Star and what would you do if it had to keep running in star?" Ie part of some critical machinery that couldn't be stopped.I assume it would run hotter but not too sure why? I appreciate Star Configuration is reduced voltage (starting ie 1/ root 3 so 254V from 440V compared to full 440V for DOL) But Is it because it might stall slightly due to reduce voltage and same load therefore run at increased slip and hence draw more current?Any help would be much appreciated?
Reply to Star Delta starter Fault... in the UK Electrical Forum area at ElectriciansForums.net
Hi Changing a 3 phase star delta motor and replacing with a dol 3 phase motor. Would i be right in thinking I can remove 3 of the 6 cables at...
Hi Guys, Is my understanding of why it is bad for a star/delta motor to be stuck in star correct? 1) Star delta starting is used as a method of...
5K
Hi there, I got a call to a job, table saw (wood) tripping C/B straight away. 4kW motor on Star Delta Starter. So I get to the job, after some...
Hi, I kinda think I know the answer to this but will ask opinion anyway. I am fitting a new compressor pump and motor to my receiver and have...
7K
Hi and thanks for any replies. I am predominantly an install electrician and don't have a lot of experience dealing with motors so any help would...
