A AJW Nov 12, 2016 #1 Can anyone help to identify this Dimplex storage heater that am removing? Have looked everywhere but can't find a model number.
O Octopus Nov 12, 2016 #2 Did you measure it? If you did you could compare the dimensions with the manufacturers information or even send them the photo and ask them........
Taylortwocities - Arms Supporter Nov 12, 2016 #3 Usually bottom right on the side near where the cable goes in, or on the base. Edit. I think it is a Dimplex XT heater. There are several models in the range depending on the elements size/ number of bricks. This may help http://www.dimplex.co.uk/assets/kb/...12.18.24_Installation_Instructions_Iss_11.pdf Last edited: Nov 12, 2016
westward10 Staff member Admin Esteemed Supporter Nov 12, 2016 #4 As a side note is that socket actually usable, sorry just curious.
A AJW Nov 13, 2016 #5 Thanks for your replies. No label to be found. Am concerned about asbestos being inside when opening it. And yep - the socket works.
westward10 Staff member Admin Esteemed Supporter Nov 14, 2016 #6 Send pic off to manufacture, they will probably know.
snowhead - Mentor Arms Nov 14, 2016 #7 If it is XT then; http://www.dimplex.co.uk/assets/kb/...12.18.24_Installation_Instructions_Iss_11.pdf XT are Asbestos free; storage heaters containing asbestos - http://www.storageheaters.com/asbestos-list.htm
A AJW Nov 14, 2016 #8 phew - thanks! i sent pic off to Dimplex over the weekend and can't get through to their customer service.
Taylortwocities - Arms Supporter Nov 14, 2016 #9 It's not easy at the best of times, And it's Monday morning............
S Steveyboy10 Jan 22, 2017 #10 The label is probably on the front cover on the inside. It's it hasn't fallen off. Is there a reason you need to know the model number?
