Talking about SWA cables, ...How many of you use ''breakouts'' when terminating SWA ends in external installations, wet/humid environments, or Switchboards etc?? Not many i'll wager!! lol!!
Humid ? I think you may have been away from Blighty a bit too long !:stuart:
not humid here, just bloody wet.
just too difficult to get the tape to stick when everything is pi$$ wet through.
If you terminate ths"string" to earth you will find you get a lower zs reading. This actually works.
Found them very hard to get from suppliers along with larger sized CW glands and believe it or not brass nuts and bolts for the banjo's. One place in London actually suggested I wrap black insulating tape around the shroud and it would do the same job.
That doesn't really surprise me. lol!!
I only asked, because being mainly involved on larger projects. i haven't seen a SWA end made off without a breakout for many years now. Same goes for MV cable lug connections, they are all mastic and booted (straight or angle). whereas in the UK, i'm told the usual way is amalgamated wrapped tape enclosing the connections....
I liked the H/S boots.
But there was one job I had to do every year where I still used varnished silk tape. OK 1250V water cooled flexible cable is a bit of an odd bod.
Agree they not only look a far more professional job, they serve many real purposes when correctly installed!! The only drawback, is having to remove them, now that can be a very mucky and sticky job and take 3 times longer to remove, than to fit them!! ...lol!!
Did any one use this type of SWA gland? For interior use only, i loved them - our local wholesaler salesman gave us a couple to try a few years ago and they were so easy to use.
I've just got that picture from google now, so obviouslly some dodgey websites are still selling them - however our wholesaler had said they have become defunct.
