Discuss Sub board in the UK Electrical Forum area at ElectriciansForums.net
Sparkyburgess
Evening all!!
I went to look at a job this evening, a lady has resently moved house and has a small outter building which she wishes to turn in to a hair salon, she wants a 7.5kw shower and 3 sockets and a light, would it be okay to run this off the existing fuse board on a 50amp breaker using 10mm swa or would it be best to run this board straight of the meter?
many thanks sparkyburgess
P.S My first post :)
Don't mean to be nasty Sparky but your profile says you are an Electrician, what do you think is the best option?
run it on its own supply.
that way if the salon is no longer required at a later date it can be disconnected with having to faff with the house wiring.
split tails , fit KMF 63A, then 16mm SWA to outbuilding. 7.5kW shower today, next week a 2nd shower, electric heaters......
Run it on it's own supply and sub meter, all costs relating to this "salon" will be deductable from taxation in anycase and the sub meter will prove the cost output for any potential HMRC investigation regarding claims via the books further down the line.
Reply to Sub board in the UK Electrical Forum area at ElectriciansForums.net
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
Hi all, Customer has built an annex and their mother lives with them. Separate Board and all wired correctly. She want a separate meter now for...
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
Good morning all, long time reader first time post so looking for some help I’m qualified as an electrician but haven’t worked as a sparky for...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
