Discuss Supplementary bonding in the UK Electrical Forum area at ElectriciansForums.net
I wasn't taught about 'path of least resistance', I was taught the science of electricity, ohms law etc.
Electricity does not 'take the path of least resistance' it splits between all available paths and the current in each path is proportional to the resistance.
It is actually directly proportional to the admittance. Or inversely proportional to the resistance if the reactance is negligible.
@OP Chris Kitcher has some good stuff on determining if a metallic part is extraneous.
Yes unfortunately touch voltage isn't really taught try reading some electrical engineering books I can provide some links if you want.
[automerge]1596147018[/automerge]
and this is wrong if you were wet standing bare foot on the ground in direct contact with mass of earth you would be getting a nasty/fatal shock you would be the path of least resistance to earth.
You are missing my point entirely.
My point is that "electricity follows the path of least resistance" is a nonsense, electricity follows all available paths. The division of current between available paths is defined by specific laws of science.
Yes, we can all come up with abstract scenarios where a fatal shock is guarateed regardless of protective measures put in place.
Yes of course If you stand naked in the rain on ground with a bonded metal pipe buried 25mm below the surface of the conductive clay you are standing on whilst poking a wire coat hanger into the L1 socket of a 125A TPN socket you will probably die.
....... whilst peeing in a puddle? ;)
After Dave's post you know he's quite a argumentative chap :p I did a little googling and it seems saying current takes the path of least resistance does get some peoples backs up and it's perhaps better to say More current will flow in the path of least resistance or even better more current will flow in the path of least impedance, I think it's a bit picky because I don't think anyone is assuming all current will flow down one path but the majority.
[automerge]1596150415[/automerge]
however saying Current takes the path of least resistance when talking about earthing something metal might seem like saying all the current will take that path, I concede to that.
Reply to Supplementary bonding in the UK Electrical Forum area at ElectriciansForums.net
So I know why it is done, where it is done and how it’s done, but I’m yet to see a scenario where there is shock danger in a typical bathroom in a...
In my bathroom there is supplementary bonding of the bath, bath pipework, and basin pipework before it goes into trunking and exits unconnected in...
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
Just a thought guys in terms of RCBO’s and supplementary bonding. Obviously supplementary bonding isn’t required as long as a 17th / 18th...
Curious about supplementary bonding, I have these two 4mm Cables loose and not connected to anything in my parents house. I presume they are for...
