- Reaction score
- 726
What's on the metal plinth, is it a PC pump ?
Discuss Supplementary bonding in the UK Electrical Forum area at ElectriciansForums.net
It is actually directly proportional to the admittance. Or inversely proportional to the resistance if the reactance is negligible.I wasn't taught about 'path of least resistance', I was taught the science of electricity, ohms law etc.
Electricity does not 'take the path of least resistance' it splits between all available paths and the current in each path is proportional to the resistance.
Yes unfortunately touch voltage isn't really taught try reading some electrical engineering books I can provide some links if you want.I wasn't taught about 'path of least resistance', I was taught the science of electricity, ohms law etc.
@OP Chris Kitcher has some good stuff on determining if a metallic part is extraneous.
[automerge]1596147018[/automerge]
and this is wrong if you were wet standing bare foot on the ground in direct contact with mass of earth you would be getting a nasty/fatal shock you would be the path of least resistance to earth.
....... whilst peeing in a puddle?My point is that "electricity follows the path of least resistance" is a nonsense, electricity follows all available paths.
Yes of course If you stand naked in the rain on ground with a bonded metal pipe buried 25mm below the surface of the conductive clay you are standing on whilst poking a wire coat hanger into the L1 socket of a 125A TPN socket you will probably die.
Reply to Supplementary bonding in the UK Electrical Forum area at ElectriciansForums.net
