Schegg
Hi all, just looking for advice prior to a potential upcoming project supply stables for horses.
The supply characteristics into the main house is TNCS and the stables are located approx 40m away from the building.
I am thinking of putting a 1w non-rcd protected consumer unit at supply end, running a 10mm SWA (25a supply) to stable end terminating into a 2way 30mA rcd main switch consumer unit to provide power and lighting arrangements.
I understand equipment needs to be IP44 and containment needs to be protected from damage so will be using weatherproof switching/socket outlets etc and installed in conduit. All sockets/switching are external to the stables and not inside, however the lighting will be inside.. obviously!
Would it be required/good idea given the the detached stables also be protected by a TT system? This is where it gets a bit confusing..
Any advice greatly appreciated (hopefully not too much criticism), little bit tricky for this little brain of mine!
