Discuss Supply for 2 x immersion heaters. in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone
I have 2 x 250 litre unvented indirect DHW cylinders. The primary heat source is the oil fired boiler, but both cylinders have backup immersion heaters. Currently, only one of them is connected - it has a dedicated circuit with a 16a mcb and a DP switch. The cable is massive - obviously the circuit was repurposed at some point - the entire run is 10mm up to the switch, with high temperature flex to the heater.
Having only 1 tank heated is pointless - if for any reason the boiler isn't working, the hot water from the working cylinder gets blended with water from the potentially stone cold cylinder next to it. I could fit valves to only draw off the working cylinder of necessary, but I can't think of a simple way of automating this and it's in an outhouse which isn't convenient for access especially at 11 pm in December which is of course the most likely time for things to break.
My question is - can I power 2 immersions from the existing circuit?
Reply to Supply for 2 x immersion heaters. in the DIY Electrical Advice area at ElectriciansForums.net
Can I supply my central heating (programmer, two port valves and boiler) via a fused spur taken from the immersion heater circuit? They’re...
I need a 3 phase immersion heater with a DN32/42 mm thread for a commercial pasteuriser. The only ones that I've found so far are not inexpensive...
Wonder if anyone can help out, my experience in heating is minimal. So house I was working in had a circuit for the water heater, which went to a...
We are replacing our Economy7 hot water cylinder due to a leak that has two immersion heaters and an indirect coil from our multi-fuel stove. My...
