A
aes2011
I have had an enquiry about a door entry system to a block of 8 flats. the stair well lighting for the block is fed from the next block.
Is the correct procedure to get a metered supply installed from the distrubutor in the block to feed a 2 way DB? There is a spare way on the service head which supplies the 8 flats.
Another option would be to take a supply from the stairwell DB in the next block. Not very convenient though.
Advice from anyone with good experience with door entry installs and supplies would be appreciated.
Cheers
Cheers
