Discuss Supply for door entry system in the UK Electrical Forum area at ElectriciansForums.net
A
aes2011
I have had an enquiry about a door entry system to a block of 8 flats. the stair well lighting for the block is fed from the next block.
Is the correct procedure to get a metered supply installed from the distrubutor in the block to feed a 2 way DB? There is a spare way on the service head which supplies the 8 flats.
Another option would be to take a supply from the stairwell DB in the next block. Not very convenient though.
Advice from anyone with good experience with door entry installs and supplies would be appreciated.
Cheers
Hi
The normal method is to use a landlords supply for power to the door entry system. Where is the stair lighting coming from? You should probably use the same source.
Frankly the amount of power consumed is very small when the lock isn't being operated. When the lock is being operated then probably less than 600mA at 12V DC (at most). Unless it's Fort Knox :)
All the best
Steve
Reply to Supply for door entry system in the UK Electrical Forum area at ElectriciansForums.net
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
I was working on a small door entry system today (4 flats ). It got me thinking , that say it was 16+ flats system , how would you go about...
Have a 63A RCD 5 Way box, with a 45A MCB, feds by 16mm2 tails, this in then feeding into a isolator via 10mm2 T&E, that then supplies the feed to...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
