UKMeterman
I am looking to replace an existing surface flourcesent fitting 4 x 36W ft tubes with an external dimentsion of 1250mm by 625mm or nearest offer.
In a school with lots of 600 x 600 4x2ft fluorescent fittings, instead of changing to LED panels, I retain the housing and fit LED mains voltage tubes. I use a make of tube where I disconnect the ballast etc, and connect each tube to 230V. Although there are 2 pins at each end only one end is fed, the other end is a dummy connector. I think these exist for 4ft tubes as well.
Try this link: LED T8 Full Glass Tube 4ft • 22W • 4000K • G13 - https://www.cromptonlamps.com/Catalogue/LED/T8/Standard/LED-T8-Full-Glass-Tube-4ft-22W-4000K-G13-LFT422CW
UKMeterman
United Kingdom
Electrical Engineer (Qualified)
Surface flourcesent fitting wanted 4x 36W 1250mm by 625 mm
Lighting Forum
Thread Tags
UKMeterman,
SJD,
