Hi Lads and Ladies (SC!),
I should have took a pic - I thought I did...
I'm after an oversized 4-gang socket with pattress. It is an surge-protected type, which I'm aware don't always apparently work as they should in relation to surges.
The faulty item in question is a massively over-sized unit probably around 150mm high by +300mm long and approx 60mm deep. Tinternet searches have frustratingly only come up with trailing extension type surge sockets.
If anyone knows a supplier I would be extremely grateful.
Thanking you, Neil
Thanking you, Neil
