Discuss Swa armour feeding TT system in the UK Electrical Forum area at ElectriciansForums.net
I have installed a TT system at my garage, and it is fed via 10mm 2 core armoured cable, does the armour of the cable have to be earthed via the supply tncs side or can it be glanded and earthed the garage side (TT).
Anyone know the regs ?
So what, you should still know what you’re doing. Your house or the enchanted castle it’s irrelevant
The armour should be earthed, doesn't matter which earthing arrangement. However I would earth to the system that would give the best disconnection time in case of fault.
Gasp!!!
I dunno, you come back to the forum after a few months and the questions just don’t get any better :) The OP clearly has no idea?!
Reply to Swa armour feeding TT system in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Might be a silly question, but can a tt supply come into a property via underground . This property in question, has no overhead cables...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
