Hi guys. Just after some advice on what you think the best way of getting swa through a cavity wall.
Do you use just use T&E, conduit and wiska boxes before transfering to swa or just go straight through with the SWA? What do you think the tidiest method is?
I only ask as I'm running power to a hot tub and the swa cable will need to come out above the front door so easily visible.
Thanks in advance
Thanks in advance
I have recently run a supply to a shed and glanded the SWA in to one of these which was sprayed black,
with a rubber gasket over the top.
Cut a hole out the back of the conduit box and thread some plastic or steel conduit on the back and poke throught the wall. Can then run the cores in conduit/trunking etc back to the board.
Looks tidier than a wiska box IMO
